Hi Artur,
Thank you for reporting this issue. As a temporary workaround you can copy the cop drivers from a different SDK (MKL16Z64 for example) and paste them in the following path.
SDK_2.2.0_MKL16Z128xxx4.zip\devices\MKL16Z4\drivers
This way you will be able to include the drivers through the SDK management window.
I hope this helps.
Felipe
Hello Felipe, I will try that and let you know in a few days.
