EPDC resolution in i.MX6UL
ko-hey
Senior Contributor II
Hi all,
I have a question about resolution for EPDC.
I found two different description of resolution for EPDC.
Datasheet P7: 2048x1536 resolution at 106 Hz
Reference Manual P1035: 1650 x 2332 pixels at 106 Hz
Which is correct ?
Ko-hey
Tags (2)
gusarambula
Hello Ko-hey,
I confirmed that the Datasheet resolution is correct. Thank you for pointing out this discrepancy and my apologies for the inconvenience.
ko-hey
Does anyone follow and answer this question ?
Ko-hey
gusarambula
Hello Ko-hey,
My apologies. I was originally looking at the i.MX6UL while I should have looked at the i.MX6ULL documentation.
I’m awaiting confirmation on which is the correct value, but I would expect the higher resolution of the datasheet being correct.
I will let you know when I have confirmation on the correct value.
gusarambula
Hello Ko-hey,
