The steps to drag and drop the file should be the same. You would need to confirm how the imxrt or the lpc55s69 is enumarating on your computer when you plug it in.
Could you please confirm how it looks when plugged in then I can check to see if you need additional steps.
Sabina
HI,
It's worked in case of imxrt1050. But we didn't get any partition mounted on windows /linux pc while connecting lpc55s69. How we can flash the .bin files to lpc55s69 from linux/windows pc ?
