LPUART in DMA mode receive , if have UART_EVENT_ERROR event , SDK 3.0.2 disable LPUART all interrupt,this is a bug ? I have to recall "LPUART_DRV_ReceiveData" API to again start data receive。
SDK V3.0.2 have other bug is here:
I don't think the SDK v3.0.2 is perfect, I added other code to work properly.
Thanks for your comments! I will pass your feedback to the SDK team.
Victor
Do you mean that when a UART_EVENT_ERROR occurs all the interrupts are disabled? If so, then this is not a bug, this is part of the implementation of the drivers that we provide.
Victor
