The error of MATLAB s32v234 evaluation board simulation
Question asked by li lei on Dec 4, 2019
Latest reply on Dec 6, 2019 by Melutu Iulian Bulancea
When I use matlab s32v234 evaluation board to simulate face detection, the following problems occur:
make[1]: Leaving directory '/g/Matlab2018file/codegen/exe/face_detection/build-v234ce-gnu-linux-o'
make: *** [/g/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/build/nbuild/platforms/coordinator.mk:57: allsub] Error 2
Who can help me, thank you
The log information is as follows:
run_application
FFmpeg library already installed
### Using toolchain: S32DS Vision GCC
### Creating 'G:\Matlab2018file\codegen\exe\face_detection\face_detection_rtw.mk' ...
Warning: coder.wref() is treated as coder.ref() when applied on a variable-sized array or a structure with variable-sized fields.
Warning in ==> UMat_int32 Line: 97 Column: 75
Code generation successful (with warnings): View report
警告: 目录已存在。
> In nxpvt_build
In nxpvt_make
In nxpvt_codegen
In nxpvt_runner/Run (line 63)
In run_application (line 7)
G:\Matlab2018file\codegen\exe\face_detection>SET PATH=G:/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/../compilers/gcc-6.3.1-linaro-Earmv7-eabi/i686-mingw32/bin;G:\Matlab2018a\bin\win64;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\Program Files\dotnet\;G:\OpenCV\opencv\build\x64\vc14\bin;C:\WINDOWS\System32\OpenSSH\;G:\vscode\Microsoft VS Code\bin;G:\OpenCV\mybuild\install\bin;G:\Cmake\bin;G:\ffmpeg\bin;G:\OpenCV\mybuild\3rdparty\ffmpeg;G:\OpenCV\opencv\sources\3rdparty\ffmpeg;G:\Python;C:\Users\rayle\.dnx\bin;C:\Program Files\Microsoft DNX\Dnvm\;C:\Program Files\Microsoft SQL Server\130\Tools\Binn\;C:\Program Files (x86)\Windows Kits\8.1\bin\x64;G:\Matlab2018a\runtime\win64;G:\Matlab2018a\bin;G:\Matlab\runtime\win64;G:\Matlab\bin;G:\Matlab\polyspace\bin;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files\NVIDIA Corporation\NVIDIA NvDLISR;G:\MinGW\bin;E:\PuTTY\;E:\Git\cmd;C:\windows\system32;C:\windows;C:\windows\System32\Wbem;C:\windows\System32\WindowsPowerShell\v1.0\;C:\windows\System32\OpenSSH\;E:\AOMEI Backupper;C:\Users\rayle\AppData\Local\Microsoft\WindowsApps;
G:\Matlab2018file\codegen\exe\face_detection>SET PATH=G:/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/../compilers/gcc-6.3.1-linaro-Earmv8-eabi/i686-mingw32/bin;G:/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/../compilers/gcc-6.3.1-linaro-Earmv7-eabi/i686-mingw32/bin;G:\Matlab2018a\bin\win64;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\Program Files\dotnet\;G:\OpenCV\opencv\build\x64\vc14\bin;C:\WINDOWS\System32\OpenSSH\;G:\vscode\Microsoft VS Code\bin;G:\OpenCV\mybuild\install\bin;G:\Cmake\bin;G:\ffmpeg\bin;G:\OpenCV\mybuild\3rdparty\ffmpeg;G:\OpenCV\opencv\sources\3rdparty\ffmpeg;G:\Python;C:\Users\rayle\.dnx\bin;C:\Program Files\Microsoft DNX\Dnvm\;C:\Program Files\Microsoft SQL Server\130\Tools\Binn\;C:\Program Files (x86)\Windows Kits\8.1\bin\x64;G:\Matlab2018a\runtime\win64;G:\Matlab2018a\bin;G:\Matlab\runtime\win64;G:\Matlab\bin;G:\Matlab\polyspace\bin;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files\NVIDIA Corporation\NVIDIA NvDLISR;G:\MinGW\bin;E:\PuTTY\;E:\Git\cmd;C:\windows\system32;C:\windows;C:\windows\System32\Wbem;C:\windows\System32\WindowsPowerShell\v1.0\;C:\windows\System32\OpenSSH\;E:\AOMEI Backupper;C:\Users\rayle\AppData\Local\Microsoft\WindowsApps;
G:\Matlab2018file\codegen\exe\face_detection>SET PATH=G:/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/../compilers/gcc-6.3.1-linaro-Xarmv8-linux/i686-mingw32/bin;G:/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/../compilers/gcc-6.3.1-linaro-Earmv8-eabi/i686-mingw32/bin;G:/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/../compilers/gcc-6.3.1-linaro-Earmv7-eabi/i686-mingw32/bin;G:\Matlab2018a\bin\win64;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\Program Files\dotnet\;G:\OpenCV\opencv\build\x64\vc14\bin;C:\WINDOWS\System32\OpenSSH\;G:\vscode\Microsoft VS Code\bin;G:\OpenCV\mybuild\install\bin;G:\Cmake\bin;G:\ffmpeg\bin;G:\OpenCV\mybuild\3rdparty\ffmpeg;G:\OpenCV\opencv\sources\3rdparty\ffmpeg;G:\Python;C:\Users\rayle\.dnx\bin;C:\Program Files\Microsoft DNX\Dnvm\;C:\Program Files\Microsoft SQL Server\130\Tools\Binn\;C:\Program Files (x86)\Windows Kits\8.1\bin\x64;G:\Matlab2018a\runtime\win64;G:\Matlab2018a\bin;G:\Matlab\runtime\win64;G:\Matlab\bin;G:\Matlab\polyspace\bin;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files\NVIDIA Corporation\NVIDIA NvDLISR;G:\MinGW\bin;E:\PuTTY\;E:\Git\cmd;C:\windows\system32;C:\windows;C:\windows\System32\Wbem;C:\windows\System32\WindowsPowerShell\v1.0\;C:\windows\System32\OpenSSH\;E:\AOMEI Backupper;C:\Users\rayle\AppData\Local\Microsoft\WindowsApps;
G:\Matlab2018file\codegen\exe\face_detection>SET PATH=G:/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/../msys32/mingw32/bin;G:/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/../msys32/usr/bin;G:/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/../msys32/mingw64/bin;G:/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/../compilers/gcc-6.3.1-linaro-Xarmv8-linux/i686-mingw32/bin;G:/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/../compilers/gcc-6.3.1-linaro-Earmv8-eabi/i686-mingw32/bin;G:/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/../compilers/gcc-6.3.1-linaro-Earmv7-eabi/i686-mingw32/bin;G:\Matlab2018a\bin\win64;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\Program Files\dotnet\;G:\OpenCV\opencv\build\x64\vc14\bin;C:\WINDOWS\System32\OpenSSH\;G:\vscode\Microsoft VS Code\bin;G:\OpenCV\mybuild\install\bin;G:\Cmake\bin;G:\ffmpeg\bin;G:\OpenCV\mybuild\3rdparty\ffmpeg;G:\OpenCV\opencv\sources\3rdparty\ffmpeg;G:\Python;C:\Users\rayle\.dnx\bin;C:\Program Files\Microsoft DNX\Dnvm\;C:\Program Files\Microsoft SQL Server\130\Tools\Binn\;C:\Program Files (x86)\Windows Kits\8.1\bin\x64;G:\Matlab2018a\runtime\win64;G:\Matlab2018a\bin;G:\Matlab\runtime\win64;G:\Matlab\bin;G:\Matlab\polyspace\bin;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files\NVIDIA Corporation\NVIDIA NvDLISR;G:\MinGW\bin;E:\PuTTY\;E:\Git\cmd;C:\windows\system32;C:\windows;C:\windows\System32\Wbem;C:\windows\System32\WindowsPowerShell\v1.0\;C:\windows\System32\OpenSSH\;E:\AOMEI Backupper;C:\Users\rayle\AppData\Local\Microsoft\WindowsApps;
Current SDK ROOT is /g/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk
make[1]: Entering directory '/g/Matlab2018file/codegen/exe/face_detection/build-v234ce-gnu-linux-o'
/g/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/build/nbuild/sub.mk:73: sub.mk: SUB_DIR /g/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/libs/apexcv_base/apexcv_common/include is missing
/g/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/build/nbuild/sub.mk:73: sub.mk: SUB_DIR G:/Matlab2018file/Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234\(2\)/code//internals/include/s32v is missing
/g/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/build/nbuild/sub.mk:73: sub.mk: SUB_DIR G:/Matlab2018file/Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234\(2\)/code//internals/libs/object_detection/include is missing
/g/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/build/nbuild/sub.mk:73: SUB_MAKE /g/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/libs/apexcv_base/apexcv_common/build-v234ce-gnu-linux-o/ is missing
/g/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/build/nbuild/sub.mk:73: SUB_MAKE G:/Matlab2018file/Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234\(2\)/code//internals/libs/object_detection/build-v234ce-gnu-linux-o/ is missing
/g/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/build/nbuild/sub.mk:73: SUB_MAKE /g/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/libs/apexcv_pro/resize/apu-nxp/build-v234ce-gnu-linux-o/ is missing
/g/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/build/nbuild/sub.mk:73: *** You can find the missing directory/directories here: /g/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/libs/apexcv_base/apexcv_common/include G:/Matlab2018file/Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234\(2\)/code//internals/include/s32v G:/Matlab2018file/Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234\(2\)/code//internals/libs/object_detection/include /g/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/libs/apexcv_base/apexcv_common/build-v234ce-gnu-linux-o/ G:/Matlab2018file/Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234\(2\)/code//internals/libs/object_detection/build-v234ce-gnu-linux-o/ /g/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/libs/apexcv_pro/resize/apu-nxp/build-v234ce-gnu-linux-o/ [/g/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/libs/apexcv_base/apexcv_common/include G:/Matlab2018file/Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234/(2/)/code/internals/include/s32v G:/Matlab2018file/Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234/(2/)/code/internals/libs/object_detection/include /g/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/libs/apexcv_base/apexcv_common/build-v234ce-gnu-linux-o G:/Matlab2018file/Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234/(2/)/code/internals/libs/object_detection/build-v234ce-gnu-linux-o /g/NXP/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/libs/apexcv_pro/resize/apu-nxp/build-v234ce-gnu-linux-o]. Stop.
警告: Cannot deploy on target. Compilation failed..
> In nxpvt_codegen
>> run_application
