I2C Interface with the Accelerometer K60
mdrasool_yadwad
   I was interfacing the K60 microcontroller with the accelerometer MMA78451Q which is available on the tower board using I2C . I am configuring Microcontroller as master and MMA78451Q accelerometer as slave. I couldnt able to find the slave address in the datasheet and also nothingabout the MMA78451Q accelerometer.
Please help me out how to interface this using I2C.
Thank You
Omar_Anguiano
Hello Mohammedrasool Yadwad
The schematics of the tower and the product page indicates that the accelerometer part number is the MMA8451Q.
I didn´t find the part number MMA78451Q in my system.
Regarding the device address, I found that the slave address for writing is 0x1C and 0x1D for reading. You can find more detailed information under chapter 5.11.1 I2C Operation in the datasheet https://www.nxp.com/docs/en/data-sheet/MMA8451Q.pdf
You can find examples for interfacing the accelerometer at the SDK. The example name is "i2c_read_accel_value_transfer" https://mcuxpresso.nxp.com/en/welcome.
Let me know if this is helpful
Omar
mdrasool_yadwad
Hello Omar,
   I will look into datasheet again . I think you are right about the accelerometer.
Thank You
Mohammedrasool
