Include standart C file in FSL SDK
EugeneHiihtaja
Senior Contributor I
Hello !
I can see in SDK examples you include standart C files as first ones and sometimes after all other #include.
Is any reason if location of those are not unified in SDK ?
Eugene
danielchen
Hi Eugene:
Thank you for your feedback. The SDK examples were developed by many engineers , maybe many have their own coding style.  The unified order will be better, I will forward your suggestion to the soft team.
For the include header file order, one rule is the headers not dependent upon other headers should be included first.
EugeneHiihtaja
Hi Daniel !
Could it be provide script for apply code format style like in SDK ?
It have sense to follow it for have similar formatting in own code as well.
Eugene
danielchen
Sorry I don't have this script for SDK. I would suggest you refer to following document.
Recommended C Style and Coding Standards
