Our customer--Spectra Technology(HK) using CLRC66303 will apply Felica cert. in mid-Dec.
In digital protocol test, there is a requirement for below two timings. May I have your suggestion that which registers can tune these two timings?
As the requirements mention, this has to be set on the application directly. This will be possible through the NFC Reader Library. Unfortunately, these specific requirements are not implemented on the examples but you may achieve it by controlling when the RF field is ON through phhalHw_FieldOn(); API and sending the command after the specified time you require.
Hope this helps!
BR,
Ivan.
