Can the local bus in MPC8270 still be used after CPU core disable? Will it be operational as a "local bus"?
vlinetsky
We are using an MPC8270 and will need to disable it's CPU core. Can we still use the local bus? Will it be operational as a "local bus"?
ufedor
Yes, you can.
