I have setup an AOSP build environment of Android 9 for imx8 Mini. I followed the instruction given in User guide.
I am able to build complete AOSP successfully. but while flashing freshly build images to imx 8Mini i am facing below issue.
I have used uuu_imx_android_flash.bat file to flash, below is the message
>uuu_imx_android_flash.bat -f imx8mm -a -e
This script is validated with uuu 1.2.135 version, please align with this version.
dtbo is supported
dual slot is supported
You do not have sufficient privilege to perform this operation.
I am not able to understand what i am doing wrong. Instead of freshly build images if I use prebuild images its flashing properly.
it seems that this needs administrative privilege to operate, if you don't have this right, maybe you can run under ubuntu
