Bluetooth LE-CAN-LIN Bridge demo issue on FRDM-KW3
enricobaiano
Hi everyone,
I had an issue during the setup of the project Bluetooth LE-CAN-LIN Bridge demo for the NXP Board FRDM-KW36.
I've followed very carefully all the steps of the guide that I've uploaded, but after the step 4) at page 8 of the guide I was not able  to build properly the program anymore. It seems that some files and some functions are duplicated after adding the drivers for FlexCAN and LIN, in particular related to memory allocation (e.g. pvPortMalloc is defined multiple times with different structures).
The project wireless_uart example demo works fine before adding the drivers for FlexCAN and LIN, after I can't build it. What might be wrong?
estephania_mart
Could you please share an screenshot of the errors you are seeing in your IDE ?
Regards ,
Estephania
