I am trying to debug MK22FX512AVLQ12 using MCUXpresso IDE and PEMicro Multilink Universal (Rev. D) but I am unable to debug. I also tried to debug the same using LPC11U68 board but still not able to debug. In both the cases I have used the SWD interface (SWD DIO and SWDCLK pins).
I have attached the screenshots of the error I get in both the cases.
Also I have observed that the RESET Pin of the controller is always in low state despite of an external pull up resistor on the pin.
Please help in resolving the issue.
Thanks and Regrads,
Vaibhavi
Hi Vaibhavi,
Can you clarify the hardware and software situation?
Jing
