Bias supplies on sub 6 GHz 5G power amplifier
john_dooley
Just reading through Datasheet document number:  AFSC5G35D37
There are 6 bias supplies in the datasheet for the board, but only three are listed in the functional test in the datasheet. I was hoping to clarify what the nominal bias levels should be for: VDP, VGP1, VGP2, VGC1, VGC2, VDC   for the test case presented in the datasheet
Thanks in advance.
LPP
Please, refer to page 5 of the board description PDF:
https://www.nxp.com/webapp/Download?colCode=AFSC5G35D37-3400-3600-MHz-Reference-Circuit&appType=lice...
Pavel
NXP TIC
