Check the LS1043a RCW SPI_BASE and SPI_EXT fields.
It looks like there is a hardware problem on your board.
This eMMC is not detected on your board.
Check connection and power supply of this eMMC.
Pavel Chubakov
Is there possibility to boot from QSPI/NOR/NAND?
Boot from QSPI/NOR/NAND and test reading writing your eMMC.
Pavel Chubakov
Hi,Pavel ;
I'm so sorry for replying to you late ,I had a holiday last weekend. My board boot form QSPI flash ,Reading eMMC information through command "mmc info” in u-boot ,
I had uploaded the log file, FYI,Thanks.
