I have actually imported a generated code from Matlab to the S32 Design software by following the below form instructions:
How to export Generated Code to S32 Design Studio IDE (applicable for MBDT for MPC5744P v2.0)
But when I build the code I will get the following errors:
1. powerpc-eabivle-gcc.exe: fatal error: cannot specify -o with -c, -S or -E with multiple files
2. make: *** [subdir.mk:155: core0_intc_sw_handlers.o] Error 1
3. make: *** Waiting for unfinished jobs....
What shall I do?
Many Thanks,
Erfan
Hello,Erfan,
I have been stuck by the same problem .Did you find the solution? I’d appreciate if you can share with me.
Thanks a lot.
Havry Zhang
