PCA85063A unused pins pull recommendation
vaibhav_waman
Hello Team,
I am using PCA85063A RTC device for automotive application, In this I will not use INT and CLKOUT pins of RTC. What would be the best option to pull it high or low to avoid it floating ? Any recommendation for pull up/down resistor for this 2 unused pins ?
Thank you.
Vaibhav Waman
Tags (2)
Fabian_R
Hello Vaibhav,
You can leave CLKOUT unconnected and for the INT pin, I would suggest using 10k pull-up resistor.
Fabian Ramirez
Fabian
