Has anyone tried keyword sporting using CMSIS-NN on ARM Cortex M4
vishal_roy
Trying to get Realtime KWS working on OM13098.Two issues I have is not sure what would be the best setting for MIC module and secondly the data transfer mechanism from mic DMA to CMSIS-NN feature extraction modules. I was able to get the demo working on this platform. But in this case the audio input was hardcoded data.
Sabina_Bruce
Hello Vishal,
Hope you are doing well. At the moment this is not supported with the LPC546xx. Did you use the following guide to port the examples to your board?
Sabina
