I do not know which product you are using. For our now product we do not use the LTIB no more, we use the yocto. For the yocto setting you can refer to https://community.nxp.com/message/363069
I really appreciate your response. We have network card, which has i.MX283 application processor running LTIB 2.6.35 build. This is actually a feature addition of an existing product. Please let me know if any reference links available for this requirement.
Thank you.
I will try my best to found some reference for you.
Could you please update ?
ijaz
1. You may find the source code of your NTP server software package. (.tar.gz file)
2. Create a .spec file in the LTIB for configure,compile,deploy of this software package. You can refer to other .spec as an example.
3. Or you can compile the source code by the ARM toolchain and then install/copy the executable files to the rootfs directly.
