How to add/create new block in fstab in Android 9?
ThanarajS
Hi All,
Anyone have idea on adding new block in fstab in android 9 for sabresd_6dq board. Please provide any information on this topic?
As we tried to add below line in fstab.freescale, but it's not added in /proc/mounts after board booting.
/dev/block/by-name/test    /test       ext4 nosuid,nodev,nodiratime,noatime,nomblk_io_submit,noauto_da_alloc,errors=panic    wait
Thanaraj
Thanaraj Subramani
shivanipatel
Senior Contributor II
Hi, rajkamsani
Please follow below mentioned links to add the new block/partition in Android.
  1. Mounting Partitions Early  |  Android Open Source Project
  2. Implementing Dynamic Partitions  |  Android Open Source Project
Hope this will help you.
Shivani
gusarambula
Hello Thanaraj Subramani,
Does the problem still remain?
There is some documentation from Google that may help:
https://source.android.com/devices/architecture/kernel/mounting-partitions-early
