RT1050 CSI with a 12-bit camera
Question asked by variable_andrew on Nov 13, 2019
Latest reply on Nov 14, 2019 by jeremyzhou
Is it possible to use the RT1050 CSI with a 12-bit camera?
I see that standard support is for the 8, 10, and 16-bits.
I'm supposing that it'd be possible to run with 10 bit and cut off 2 bits of data....  Any way to maintain all data?
The camera we're using provides 12-bit data (either black and white or bayer format).
We've tested it with the RT1020 via the FlexIO interface. Sounds like the CSI is a better solution for camera vs plain FlexIO...., right?
