现用codewarrior 10.7编译工程出现:
v11.0以前安装过,已经卸载。这个10.7工程的系统头文件调不进来,是v11.0的,删除不掉。请问怎么处理?
Hello bingguo zhang ,
Please check the "System Path " as below, you can change here to the real path:
And you can also define the Variables at here:
Hope it helps,
TIC
