What is the port pin status of ball E13 "IFC_PAR1/GPIO2_14/QSPI_DIO_B1/FTM6_CH1", while LS1021A is set into RESET state?
Datasheet (Rev. 7, 06/2019) doesn't provide any notes for this pin. Is there any internal weak pull resistor applied or is the pin in high-z mode?
The pin is tri-stated when PORESET_B is asserted.
