HI,I need your help with some questions
When i use this function ZPS_eAplAfUnicastAckDataReq( ), I need to apply for some APUD.
I know this function ZPS_eAplAfUnicastAckDataReq have Retransmission mechanism, so I would like to know if releasing the APDU immediately,will affect subsequent retransmissions?
The function ZPS_eAplAfUnicastAckDataReq,Will it release itself if it's sent?
韩
Hi, I hope you're doing well!
Releasing the APDU shouldn't have an impact in the possible retransmissions. As for the ZPS_eAplAfUnicastAckDataReq function, the APDU is not automatically freed or released, so you should use the FreeAPDU function after the request.
Please let me know if you need any other information.
Sebastian
OK,Thank you for your reply
