Could someone on how to edit Flexray sample code with user defined functions and compile successfully ?
I tried by adding a simple user defined function (which writes to console ). It does not seem to work.
I have also included the required headers.
I get few warning indicating "Functional call return value is ignored"
Any sort of help is welcomed. I am really stuck.
Setup:-
Code warrior Dev studio V5.9
Windows OS
Sample code trying to edit: EVB9S12XF512E
Rakshith Shnabhag
Hello Rakshith,
According to your second request in salesforce, you are trying to use fopen and fprintf.
A similar question was discussed in this thread.
Write in a file in Codewarrior
Diana
