Yocto&Soft AP
Yocto&Soft AP
li_hong
Hi, Team:
         I try using  soft AP based on yocto. When I run the command of "hostapd -B /etc/hostapd.conf -dd", the hot spot can be found , but my phone can't connect to it。
         I've uploaded a image that show my connection status.
         How to modify the file named “/etc/hostapd.conf” or other ways to solve this problem.
romitchatterjee
Contributor V
Since you can see the hotspot, I guess hostapd is working. Can you share your hostapd.conf file? Are you running udhcpd on your board?
diegoadrian
Have you tried adding the recipe into the Yocto building?
If no, please make it as following:
IMAGE_INSTALL_append = “ hostapd”
Hope this could help you.
Diego.
li_hong
   Thank you for your reply.
   The recipe named hostapd is already in the Yocto building.
Best regard
diegoadrian
I apologize for the delay.
Remember that the Recipe needs some dependencies, do you have them?
  • initscripts
  • libnl
  • openssl
  • pkgconfig-native
  • update-rc.d
Diego.
