I.MX 6( MCIMX6S5EVM10ADR) BPM Microsystem programming
marco_villasana
Good afternoon, we are using the I.MX 6 in some of our products, we are currently using the NXP Mfg tool to program this device on board. We are willing to move this programing to a device level, prior to mounted on PCB, is it possible to program this micro using a programmer? (BPM machine in this case)
Hi Marco
i.MX6 have not internal program flash, they use external media like
sd, or nor which may be programmed using programmer.
marco_villasana
Thank you for your answer What about IMX8?
Regards!
it is the same
marco_villasana
Thank you for the quick answer, so, just to be clear, the IMX6 and IMX8 can not be programmed using any kind of programmer right?
right.
marco_villasana
Thanks for your attention
