I am using LIN FSL_LIN_2.x_STACK_Package_4.5.9 package to implement a master LIN node on J2602.
I found a problem in the code that needed to be improved
/*** MARCOS ***/l_u8 bus_activity; /**< Bus activity timeout LIN 2.1*/
l_u8 bus_activity:1; /**< Bus activity timeout LIN 2.1*/
Hi he maoyi,
I've downloaded this package in the following link and this error was already corrected. Are you sure you download it the last LIN stack?
Alexis Andalon
