BATS module assert voltage level changes in negative temperature environment in S12/MagniV
Question asked by Venkateswara Ballary on Nov 8, 2019
Latest reply on Nov 19, 2019 by Daniel Martynek
Thanks for the earlier support..
i am using MC9S12Z. micro, on my application i have configured the BATS module for generating low voltage interrupt. i have configured Low Voltage Warning (LBI 1).. At 25 deg ambient temperature it was working as defined in datasheet voltage level but if kept the micro in -40 deg c, voltage level will be vary around 0.2 to 0.4V. let me know, this is the intended behavior for at -40 deg c.
example: at 25 deg, BATS interrupt occurs within the defined range in datasheet
                at -40 deg BATS interrupt occurs 0.2  to 0.4V for defined range.
Please need some support on this..
venkat.
