hello,
How to dump camera raw data that not pass through ISI to verify pure camera data correct or not on i.MX8?
do you need to check the raw data from camera? if yes, you should dump the memory which store the camera data
It is yes,I try to dump memory after V4L2 dequeue operation,does it the pure camera data not pass through i.MX8 ISI?
you can send the camera data to memory, then read the raw data from memory,don't dump memory after v4l2
