LPC55S69 : Flash programming constrains
Question asked by Eugene Hiihtaja on Nov 7, 2019
Latest reply on Nov 25, 2019 by Sabina Bruce
Hello !
1.
UM chapter 4.6.5.2 give Note :
Note: Flash ERASE and PROGRAM operations must be performed with a system clock
below or equal to 100 MHz.
So if I have clock 150 Mhz , I shouldn't erase and program flash memory. Is this so ?
Is exists any examples how-to change MCU clock on fly safetly ?
I assume peripherals clocked from independent clock source  and we should adjust system clock and something else in safe way. How to do this on fly ?
2. Flash API is integrated to Bootcode and it is not clear if after erase/write operations some caches/flash accelerators
   should be cleaned/invalidates. Like it was done for K82.
  Or everything is done inside those APIs and I should disable/enable interrupts for avoid ISR execution from Flash memory if I need to ?
3. If I undestand right and minimal erasable unit of Flash memory is  512 bytes.
  Does exists any other bigger erasable sector ?
Or if I would like to erase 8KB space , erase time will be 16*21ms ?
Eugene
