MPC5748G:S32软件debug烧写不进去
he_zhang
IMG_20191106_184949.jpgLoading programming algorithm . . .
WARNING - Selected .PCP file has been modified. CRC16 = $5A63
Done.
Programming sequency is : erase, blank check, program, and verify { default }
CMD>VC
Verifying object file CRC-16 to device ranges . . .
      block 00F90000-00F9001B  . . .
在使用软件debug调试时,烧写代码,卡在99%,上述为log,好像是芯片无法擦写了?
mariuslucianand
Hello 张 贺 ,
Do you generate the code using Model-Based Design Toolbox for MPC57xx? Because on this community we try to respond to questions related with the NXP's Simulink Toolbox and I've seen that your elf is called Debug_sample_boot_mcal_1M.elf.
Marius
