Hi Sir:
Our design has the system performance issue during high temperature, our BOSS would like to explore replacing the current part MCIMX6X4CVM08AC (industrial version -40C – 105C) with MCIMX6X4AVM08AC (automotive version). A few questions:
PS: the attached file is the compare result from NXP website.
Thanks!
Samuel
The two chip the most difference is the temperature, and others you can see in the excel you attach. The questions you ask above, here I give you reply one by one:
1\The application scenarios are different.
2\ I am not sure, I will confirm it.
3\Software compatible.
4\The i.MX6SX support GPU
5\Yes, pin to pin, hardware design reference here
i.MX 6SoloX Applications Processors | Arm® Cortex®-A9, Cortex-M4 | NXP
Anyone could help to answer it?
Anyone could help to advise?
