GPU (Galcore.ko) is not working on .mx6-SOLOsabresd
noammoshe
In one of our boards we use i.mx6-SOLOsabresd  (MCIMX6S5EVM10AC) with Embedded Linux. Our current versions are:
  •       Kernel 4.1.15
  •       Jethro (Yocto version 2.0)
In order to apply a certain feature we need to upgrade the BSP (Kernel, Linux,..). We tried:
  •       Sumo (Yocto version 2.5) version with kernel 4.14
  •       Rocko (Yocto version 2.4) version with kernel 4.9
  •       Rocko (Yocto version 2.4) version with kernel 4.9.88 (specific version)
Using the next images:
In all of the cases we encountered with the same problem – the GPU (Galcore.ko) is not working, we cannot run our graphic apps.
We need a solution for i.mx6-SOLOsabresd (MCIMX6S5EVM10AC).
Notes
Bio_TICFSL
Hello Noam,
For galcore you need to run the 5.0.11 version of the vivante driver and kernel 4.1.15, this don´t work for newer BSPs because NXP doesn´t  have the MX6SoloSabreSD.
noammoshe
Dear Bio_TICFSL Employee
In order to apply certain things I need an updated BSP, the current version (4.1.15) does not help me.
What does it means?
