How to S32's break point timestamp in running
guoqiang_zhu
   I want to konw the time consumed from breakpoint A to breakpoint B. but I don't know how to do it.
background:
  a. Project quesion is MCU Init time too long , I think the time cost in StartUp step .
  b.address 0x01000400 is my StartUp's Entry point , address 0x01008e24 is my MainFunc()'s Entry point.
thanks.
jiri_kral
I'm afraid that PE Micro isn't able measure running time.
You can attach one channel of oscilloscope to Reset. Add as a very first instruction in main pin toggle. Catch this pin toggle on second oscilloscope channel. You got time from reset to main.
Anyway, what's your target MCU?
Jiri
jiri_kral
Jiri
guoqiang_zhu
Thanks for you response.My target mcu is MPC5746C.
And oscilloscope can slove my current problem by adding two pins toggle channel.
