Share data between XGATE and S12X
Question asked by KoT on Mar 12, 2009
Latest reply on Mar 16, 2009 by Tom Thompson
I use for working out of program CodeWarrior 4.7 for HC12X.
The code such:
main:
#pragma DATA_SEG SHARED_DATA
volatile int shared_counter; /* volatile because both cores are accessing it. */
volatile unsigned char* p;
#pragma DATA_SEG DEFAULT
xgate:
volatile extern int shared_counter; /* volatile because both cores are accessing it. */
volatile extern unsigned char* p;
With variables all works remarkably but if it is necessary to use the pointer problems begin. In XGATE and in HC12 under the same pointer there is various data. I believe that the pointer specifies in various cells of memory in XGATE and in HC12.
Prompt as to be?
