LPC55S69: HASHCRYPT and AES-GSM
EugeneHiihtaja
Senior Contributor I
Hello !
I can see HASHCRYPT is not supports AES-GSM directly.
And in ksdk_mbedtls_config only alternatives defined for
#if defined(MBEDTLS_FREESCALE_HASHCRYPT_AES)
#define MBEDTLS_AES_CRYPT_CBC_ALT
#define MBEDTLS_AES_CRYPT_CTR_ALT
#endif
But it is not so clear if some hybrid model can be utilized and HW accelerator partially in use ?
Could you confirm that current AES-GSM implementation is done by pure SW ?
Eugene
ZhangJennie
Hi Eugene
LPC55S6x AES engine supports 128/192/256bit key in ECB, CBC and CTR mode.
"Do I understand  right and this is the same HW block what is mapped to mbedtls library ?" >> yes, you are correct.
AES engine doesn't support AES-GSM mode. So far as I know, SDK SW doesn't support it either.
Jun Zhang
ZhangJennie
The LPC55S6x devices provide an on-chip hardware AES encryption and decryption engine to protect the image content and to accelerate processing for data encryption or decryption, data integrity, and proof of origin. Data can be encrypted or decrypted by the AES engine using a key from the PUF or a software supplied key.
Jun Zhang
EugeneHiihtaja
Hi !
in AN12278 I can see:
The AES block supports symmetric cryptographic using AES- ECB, AES- CBC and AES-CTR modes with side channel protection for key wrapping.
And if I need AES-GSM operations, they done by pure SW only. It is no any hybrid schemes for have better performance ?
Eugene
ZhangJennie
Hi Eugene
Jun Zhang
