S32DS v2017.R1 PA license missing
nxf54120
Whenever I open S32DS this window pops up, and I inputted the license key from my software account which is valid till 2023 but the it says its expired. Is this a bug?
mikedoidge
Hello nxf54120‌,
It could be there is a file which has become corrupted. If you try pressing the 'Activate' button and enter the activation code again and the problem returns, then I suggest you try to reinstall. If you will reinstall, then perhaps you should consider to install the new version we released earlier this year.
https://community.nxp.com/docs/DOC-343864
Hope it helps,
Mike
