Dear Responsible;
In T1042RDB For LVDS interface the used transmitter DS90C387R is -10~+70C rated and i need an extended counterpart with at least -40~+85. could you pls recommend me an alternative?
I found
DS90C385A
DS90C383B
SN65LVDS93B-Q1
(DS90CR287)
(DS90CR285)
THC63LVDM83D-Z
THC63LVDM83C(5S)
THC63LVDM83D
as alternatives but not sure one of them is okey.
DS90C387R has 12 bit data interface but the above alternatives have 24-bit data?
By the way, is there any tutorial about DIU explaining it deeply?
The 1042 DIU supports double-pumped pixel data for a low-pin count, 12-bit-wide DDR pin interface to support up to 24-bit RGB.
Find LVDS double transmitter.
See the VT1631:
https://www.viatech.com/en/silicon/legacy/video-display/vt1631/https://www.viatech.com/en/silicon/legacy/video-display/vt1631/
Pavel Chubakov
