I created a new project with "S32DS project from a example",but an exception message occurred when I compiled.
I don't have any ideas,can you help me?
thanks!
Solved! Go to Solution.
Thank you for your help. I have solved my problem, which was caused by the encryption system
this is output from build console.
unfortunately your attached project is somehow encrypted. So - it looks that there is some syntax error in linker script file. Can you share your .ld file?
Jiri
can you please share output from build console?
Jiri
