USB DMA Read Endian Select
Question asked by Austin Wilhite on Oct 25, 2019
Latest reply on Oct 29, 2019 by Hui_Ma
Operating in USB Host Mode, I'm using the USB Audio class to read 16-bit, 16kHz PCM audio from a connected microphone.
The algorithm that processes the audio requires that the samples be in big-endian format; however, it appears that all USB data is transferred in little-endian.
I noticed that the USB Device Mode has an Endian Select field to switch between the two types, but I have not been able to find any mechanism for converting from little-endian to big-endian when reading USB audio in host mode.
Can anyone suggest a mechanism to accomplish this?
