HI rike yao
There is emWin demo code included in LPCXpresso55S69 SDK, make sure you select emWin component when download SDK.
demo is under folder:
SDK_2.6.x_LPCXpresso55S69\boards\lpcxpresso55s69\emwin_examples
Hardware requirements
- Micro USB cable
- LPCXpresso55S69 board
- Adafruit TFT LCD shield w/Cap Touch
- Personal Computer
Hope this helps.
Jun Zhang
thanks, Jennie.
would you give me a link for buy "Adafruit TFT LCD shield w/Cap Touch" in jd/tmall/taobao? I'm not familiar with touch, afraid of buy a touch with 55s69 screen. thanks in advanced.
br
Rike
Hi Rike,
I'm using both the resistive and the capacitive touch (https://www.adafruit.com/product/1947) screen from Adafruit with the LPC55S69-EVK. I recommend the capacitive one because this one does not require special calibration and works very well.
I have a project available on GitHub:
This project uses the open source littlevGL GUI (see LittlevGL - Open-source Embedded GUI Library and Tutorial: Open-Source Embedded GUI Library LittlevGL with i.MX RT1050-EVK | MCU on Eclipse ).
I hope this helps,
Erich
thank a lot, Erich and will have a try to duplicate the demo.
br
Rike
Hi Rike,
I plan to write up an article on MCU on Eclipse | Everything on Eclipse, Microcontrollers and Software over the next days because the board/LCD needs a hardware modification to work with the LPC55S69.
Erich
hi, Erich,
that's great
when it's ok, would you inform me ?
br
Rike
Article is published now with Open Source LittlevGL GUI Library on Adafruit Touch LCDs with NXP LPC55S69-EVK | MCU on Eclipse
I hope this helps,
Erich
Hi Rike,
Yes, I will post a message here.
Give me a few days.
Erich
Rike,
This touch is not NXP product. I don't have it in my hand. But I think it should refer this one:
Jun Zhang
Jun Zhang
