S3DS Freertos heap usage qeustion.
fred_liu1
Hi ,
I have a issue when debug FreeRtos .
I'd like to check the heap usage view but it shows Heap 5 regions (XHeapRegions) are not defined .
You can check bleow screenshot ,could you kindly help check why cause that and how i can check the heap usage ,thanks (The Timer list and queue list work properly )
Tags (2)
jiri_kral
what's you S32DS Version and target MCU?
Jiri
