[S32K148] No CLKOUT from SOSC_DIV2
Question asked by Yin Chaoping on Oct 21, 2019
Latest reply on Oct 23, 2019 by Yin Chaoping
My setup is not using SDK, but AutoSar package instead.
Now, I want to use CLKOUT pin(PTE-10) to monitor SOSC_DIV2 frequency, but failed.
(If monitor other clock outputs(FIRC, SIRC...), all are no problem, only SOSC, no output generated!)
My SCG registers setting shows below:
SIM registers setting as below:
So, from the Clocking diagram in S32K1xx user manual, I didn't find any mistake.
Could someone support me about this issue? Is there any other configuration I need to check?
Thank you.
