How to build and use emulator for imx8m board
Question asked by Maneesh Singh on Oct 17, 2019
Latest reply on Oct 22, 2019 by Diego Adrian Cuevas
Hi Sir,
I am using imx8m mini EVK and Andriod 9.0 AOSP version.
I am successfully able to download and build the AOSP for imx8 EVK board and it is working fine.
To build the AOSP for imx8mm evk I used below commands -
      $ source build/envsetup.sh
      $ lunch evk_8mm-userdebug
      $ make 2>&1 | tee build-log.txt
But I want to use emulator for my some development and testing activity.
When i execute emulator command   -
      $ emulator
then emulator opens but it is not booting and working at all.
In some blogs and AOSP documentation it is mentioned that it will work for - lunch aosp_x86_64-eng
But I want to use emulator with my imx8 mini EVK board. i.e. - lunch evk_8mm-userdebug
Please suggest how can I use emulator for my imx8MM build i.e. for ->  lunch evk_8mm-userdebug
What all changes and setting will be required for doing it.
Thanks & Regards,
Maneesh
