I would like to use a passive NFC tag to read data from a temperature sensor and also to be able to read the value of some resistors.
This tag will have to work on a metal surface and be able to resist temperature variations.
Is there any tag like this that could work on a metal surface?
Thanks and Best regards,
Liviu
I believe it will be helpful to check the following video first for a metal environment: NFC Antenna Design 3: Metal environment | NXP
Hope it helps.
BR,
Ivan.
