I have to describe uP MPC5744P.
"Not Safety related faults" should be considered in the final FMEDA?
The ISO 26262 says that the total lambda are given by: (SPF + RF) + MPF + SAFE
It never mentions NSR.
What is the method?
Hi Davide
I could not understand your question. Can you please be more specific and provide reference to the exact section in the FMEDA which is relevant for the above query?
-Aarul
Hi Davide
I did not hear back from you. Let me try to answer anyway.
The failures of non safety related HW element are not considered in safety analysis. You may refer Appendix B of ISO26262-5:2018 for the same.
Hope this helps,
-Aarul Jain
