IMXRT1050-EVKB   -  Fatel Error : Failed to connect to CPU Session aborted !
Question asked by Derek Choi on Oct 14, 2019
Latest reply on Oct 15, 2019 by jeremyzhou
Hi ,
    I have problem with my IMXRT1050-EVKB. It seems that it is easy to have fatal error after programming FW into external flash for several times .   Two boards have been damaged with this error message and I cannot program the flash again.    One board has been modified for booting up from QSPI flash instead of Hyper flash according to Application Note.    Both broads are working fine in the beginning.  Unfortunately there is fatal error after using for some time.    Do anyone have idea about this problem ?   Thanks
