Luis Hernandez Salvador
Kinetis MK66, how overclock to 240Mhz
Discussion created by Luis Hernandez Salvador on Oct 11, 2019
Latest reply on Oct 12, 2019 by Luis Hernandez Salvador
Hi.
I want to apply overclock to a Kinetis MK66, to run at 240Mhz, I know it is possible because with the Teensy 3.6 I can apply an overclock at 192, 216 and 240Mhz, using the same microcontroller.
But I prefer to work with MCUXpresso, the problem is that I don't know how to configure it here, I have tried several combinations of the PLL but it always gives me error. The only sure  is that the maximum frequency of the VCO is 360Mhz according with the datasheet.
