Flash Programmer Device
rogelio_rafael
Hi.
I need your support, we are currently developing a programming station for a production line.
Please, you can help me select a programmer device with support to flash the MWCT1013VLH IC.
The programmer device may be to use in Windows 7 or latter.
If is required more information we are you service to shared.
xiangjun_rong
Hi, Rogelio,
Regarding your question, of course, the CodeWarrior for mcu ver11.x tools provides the Flash programming function, pls refer to the following screenshot:
Pls have a try.
XiangJun Rong
rogelio_rafael
Hi xiangjun.rong thank you for the answer,
One question, what is the model or part numbert of programmer device used to flash the MWCT1013VLH IC.?
Best Regards
Rogelio R
xiangjun_rong
After you click the "Flash File to Target", you can follow up  the the following configuration to erase/program the application for the MWCT1013VLH IC.
Hope it can help you
XiangJun Rong
rogelio_rafael
What is the model of programmer device used or with coverage to flash the MWCT1013VLH IC.??
Some example of other programmer device models: (But this devices not have a coverage for flash the MWCT1013VLH IC).
Flash Runner FR Cube
Algocraft
Renessas FP-5
Best Regards
Rogelio R
xiangjun_rong
Hi, Rogelio,
As you know all the following tools are third party tools, I am not sure if they can program flash of MWCT1013VLH IC, I think the MWCT1013VLH IC. is the same as MC56F84789, if it includes the MC56F84789, it is okay.
Algocraft
Renessas FP-5
XiangJun Rong
rogelio_rafael
Hi xiangjun.rong thank you for the answer again,
I am would like adquire a programmer tool for flashing the MWCT1013VLH IC, of NXP but i not shure which tool adquire.
Can you recommend some model of tool, please.?
Best Regards
Rogelio Rafael
xiangjun_rong
Hi, Rogelio,
The CodeWarrior for MCU ver11.x tools provides the tools to program on-chip flash of MWCT1013VLH, have you tried to use it?
Regarding the third party tools, I am not familiar with.
Xiangjun Rong
