We have written code for eQADC_A in mpc5777c and set to 1.2Msps.I have configured ADC for 2 channel for which I have used both the adc one for each channel with software trigger single scan. The results are stored in 2 different RFIFOs ,but when I store the results in certain variables the values of the variable doesnot change as instantaneous as the values of RFIFO changes.What could be the possible reason?
Hi, I believe it is caused by incorrect DMA source used as described in your second thread:
